Re: Anybody,your option on synthetic motor oil for a 440?
[Re: Rug_Trucker]
#427753
08/04/09 10:02 PM
08/04/09 10:02 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
People are getting silly about oil anymore, additives etc..
You may have a point there...
Zinc Concentration (ppm, ICP) : Though viscosity is critical in terms of wear protection, it does have limitations. Component loading can exceed the load carrying ability of the oil. When that occurs, partial or full contact results between components and wear will occur. Chemical additives are added to the oil as the last line of defense to control wear in these conditions. These additives have an attraction to metal surfaces and create a sacrificial coating on engine parts. If contact occurs the additive coating takes the abuse to minimize component wear. The most common additive used in internal combustion engine oils is zinc dithiophosphate (ZDP). A simple way of reviewing ZDP levels within an oil is to measure the zinc content. It should be noted that ZDP defines a group of zinc-containing compounds that vary in composition, quality and performance. Quantity of zinc content alone does not indicate its performance. Therefore, it cannot be assumed that oils with higher concentrations of zinc provide better wear protection. Additional testing must be reviewed to determine an oil’s actual ability to prevent wear.
Work Cited
Entire Thread
sixty7gtx
08/04/09 12:30 AM
stumpy
08/04/09 12:39 AM
Thackdaddy
08/04/09 12:57 AM
sixty7gtx
08/04/09 01:07 AM
dOc …
08/04/09 01:08 AM
Stanton
08/04/09 01:23 AM
Posest
08/04/09 02:01 AM
sixty7gtx
08/04/09 02:07 AM
MACDiesel
08/04/09 06:22 AM
mopar376d
08/04/09 07:09 AM
SomeCarGuy
08/04/09 03:03 PM
deansrr
08/04/09 03:13 PM
shart70rt
08/04/09 03:28 PM
DennisH
08/04/09 04:22 PM
dOc …
08/04/09 11:37 PM
CompSyn
08/04/09 11:49 PM
Frank Raso
08/04/09 06:28 PM
68Cbarge
08/04/09 11:06 PM
sixty7gtx
08/05/09 12:58 AM
CompSyn
08/04/09 11:43 PM
sixty7gtx
08/05/09 12:55 AM
Pacnorthcuda
08/05/09 12:59 AM
Frank Raso
08/05/09 01:23 AM
Rug_Trucker
08/05/09 01:33 AM
CompSyn
08/05/09 02:02 AM
Frank Raso
08/05/09 02:03 AM
CompSyn
08/05/09 02:35 AM
sixty7gtx
08/10/09 06:27 PM
Dougsmopars
08/11/09 08:46 PM
Frank Raso
08/11/09 09:15 PM
rbstroker
08/11/09 11:55 PM
Frank Raso
08/12/09 12:19 AM
Dodgem
08/05/09 01:28 AM
451Mopar
08/12/09 07:26 AM
terzmo
08/12/09 11:09 AM
