Be a lot easier to narrow a longitudinal torsion bar setup than it would the transverse torsion bar setup.
For the longitudinal setup you'd section the K member and centerlink (could probably find a narrower cneterlink easy enough). For the transverse, you'd do the same but also you'd have to shorten the torsion bars.
hey supercuda, it's easy to lose me with the super technical jargon. can i get the low-tech translation? thanks, mike in k.c.
ask me about new sportone elbow side trim for your 1957 and 1958 plymouths http://39lowboydodge.blogspot.com/
