11.75 rotors on 73-76 A body spindles....
I just checked www.rockauto.com and got some prices on the new stuff...
11.75" Rotors: $60 each new
inner,outer bearings & seal: $18/side new
Spindles with sheilds and 10.75 caliper adapters: $150-$200 pr for 73-76 A-body and $100-$150 for FMJ-body used
Calipers: $45-$60 each with pads $60 w/semi metalic pad new rebuilt
11.75 caliper adapters: $60-$100 used
caliper hoses: $60-100 pr braided new, $25 pr rubber new
disk master: $65 new rebuilt
adjustable proportioning valve: $45 (Mancini) new
I come up with $661 for all that. Minus $50+ if you use FMJ spindles. Minus $100 if you use $10.75 disks
For an A-body you will need some used upper control arms and lower ball joints.
