i pulled mine out 7 different times and went through at least 14 keystone clamps, i tried everything to get it to work. what i dont understand, i plugged in the sending unit switch wire to the unit, turned on the ignition switch, flipped up the lever and it read full on the gauge, i go and installed it and all i can get is 3/4 full with a totally full tank.
