Quote: I have a high volume pump but I never had this problem before I started to mess with the carb. I have lot of good things to check now and appreciate all the help!
I'll let ya'll know how she turns out tomorrow!
Thanks a million fella's
electric or mech??? either way you need to check for pressure?
Also you might want to drain the oil soon with all that gas dumbing in there it could get in the crank case.
