I have a mini starter in my D100 that has started acting up. When you hit the key and crank the engine it makes clicking noise while it is cranking. It always fires up but the noise is new and I figure it will eventually quit.
Is it the starter or should I look for something else? I'm going to start by making sure all my connection are good, clean and tight but what else can I check?
Thanks for all your input in advance
1973 Dodge D100
