Thanks guys, that's what I will try. Thanks Robert for the chart too! Man when does the stock springs go to full advance Must be 2800 with size of that spring!
The other springs listed are in a Crane kit that is no longer available but I'm sure nowadays there are other springs available(MSD??). yes the stock setup w the light spring and the heavy one w the long loop it'd be lucky to be all in by 2800
