What do you have for a fuel pump and what is the pressure? When the motor starts crapping out (but way before it's ready to die) pinch the fuel line close and rev the motor once to clean it out and see if it idles ok for a while with the line pinched. Before the motor runs out of fuel release the fuel flow again. See if it wants to crap out, Repeat
Just something to try.
It's a standard carter. No fuel pressure gauge on it, but again, it's getting fuel to the carb.
One issue it had last night is that when I turned it off, the primary boosters kept dribbling fuel. Another is that I have again fouled plugs. No gas smell this time, but definitely carbon-fouled.
