Thanks for all your help!
Just one more question...or more
Why would I need to plug the hole marked in white?
Wouldn't it just be ok to plug the "in" in the adapter that sits in the original place for the oil filter (see the top photo in 1st post).
Then from the "out" from the new oil filter mount (2nd pic) I would put the line directly to the tapped hole in the front of the block.
Getting closer... <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
