patrick also mentioned tuning the power valve, but not sure which way to go with it. the slight hesitation is now from dead stop to about 25-30mph after that no problem and no problems in park either.
He is saying to get the PV closer to your vac point
so there is less time for it to open during your
transition (most likely you would need to raise the
PV number)
