I would suspect that most of any gains in the manifolds flow would be in the matchin of the portd to the exhaust ports on the heads and also at the exhaust pipe flange as there is a bit more metal on the flange end. About $500-600 for a 3 HP gain seems like a waist. I think you woud gain more by hand porting the exhaust manifolds and Extrud Honing the intake.
