Quote: There is no vin stamping on the pan rail but I did find what looks to be a vin stamp on top of the bell housing right where the trans lines up? Was there something peculiar to the 68 cars?
That's where it's supposed to be on a '68 engine.
What he said , that's the 68 location , if the car has an auto trans the trans is stamped in the same location as the engine , 4 speed will be stamped down on the side same as 69 up ...
'68 (rr short block) engine/VIN location - driver's side/top/rear
