probably 160 stat as it came out of Atlanta.My GTX runs between 200 and 220 I noticed that the temp rose about 10 degrees after I installed a new clutch fan.
If it does have a 160 in there I would put in a 180. You R&R'd the old clutch fan for a new one & temp rose? I would want it a bit cooler. More details on what the temp is around town & the highway and what do you have for radiator? What timing idle/curve & plug color.
