While not exactly for stock OE gas tanks, how is the accuracy of the Tanks Inc floatless and reed sending units? Holley also has a laser sending unit. Wonder if these are any better. Most gas tanks are tucked way up under, so using an EFI gas tank (minus pump of course) on a restoration build or one with carburetor, might be a solution to the sending unit issue.
