OK, so after more searching for information it appears the Fel Pro 45996 is a silicone steel core gasket for the timing cover, better, but doesn't help with water pump gasket. This is a kit that appears to include their blue stripe paper water pump gaskets which although perform perfectly well are the bane of my existence
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
