Originally Posted by Mr PotatoHead
Good deal.
I had always thought they were one in the same but just a name change in the public view. Unless they changed in the last two years the heads all have the PCE part numbers. The sets ive got from 2012 is identical to the 2022 castings. Not sure if I have the 2012 invoice to see if it says PC or SM. Such junk castings from 2012 are still going strong and getting abused. whistling
Not that any of it matters. Ive looked at some of the stuff you have done on fabo. I should probably look on fabo but did you ever plug and re drill for offset pushrods/rockers?
I’ve done it an recommend not doing it. The pinch isn’t the problem. Edelbrock or Speedmaster heads can and will flow over 330cfm with a 2.08 valve without moving the pinch. Stock rocker offset.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
