Originally Posted by gregsdart
Because your deck height, cam base circle, and head and gasket thickness can all be different for each build, it is best to get a measuring pushrod and find out exactly what works for your combo.
I have those, the only thing changing is stock 452's to Stealth heads. I can't use the stock pushrods due to new rockers but if I don't have to custom build them it would be preferable.
eBay-cdwmotorsports
