I believe the adjuster WITHOUT the locking nut is the OEM adjuster. They are an interference fit designed to not use a locking nut. The others are an aftermarket replacement with the familiar adjusting screw with locking/lockdown nut. As mentioned, replace them all with Smith Bros components. Maybe ensure the surface the locking nut will seat down onto is filed down flat so the nut is not forced to seat against an irregular surface.
Keep old mopars alive.
