The benefits of a solid regardless of performed gains is worth going solid. You never have to worry about collapsing or pumping up a lifter. The maintenance of a solid is way over stated. I check once a year. Which is like a physical for your engine. Lash opening up? Early warning sign.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
