Saw the range is 291 miles- for a half MILLION dollars. If you are poor and have to settle for the base model at 425k, you can expect 261 miles. Charging times are also still painful, at 34 minutes to get to 80%.
All this to say, there isn’t a better ev coming. The logic that the masses in 20 years will be using what the rich are today shows this pipe dream isn’t coming to reality. Passing a law won’t cause a sudden technological breakthrough. Once the gassers are all worn out or the fuel is banned, you’ll be stuck within two hours of home unless you want to spend the night. Driving cross country will be a nightmare. Of course the cool people in their private jets will still be dumping fuel over your heads and talking about how they love the environment.
