Originally Posted by FurryStump
Let me look for pictures of it installed.
Thxs for the info. up ? those pictures you posted on the TPS is six wire/pins and most of the one i see are the three wire .Do you wire in all six of them into your system?
No, that sensor measures the position and the rate the throttle is moving. I figured out which pins showed variable resistance when moving the arm and used them. Most sensors use 0-5 volts. When logging data you configure the channel so the range of data you display relates to the 0-5 volt range. You tell the logger that zero volts equals zero throttle and 5 volts equals full throttle and it displays the valve throughout the range.
Thank you. up
