Originally Posted by rapom
Figures,
Well thanks for the info guys. At least I will be able to mock up my test stand while searching for a flywheel.
No need to search. 440 source has a new billet flywheel, 130 tooth, and an add on weight for cast crank applications. Touch base with them to verify 440 cast crank. Under $250.
