Originally Posted by rapom
The flywheel and bellhousing are from a 70 383 from a challanger r/t. The 440 is from a 1978 motorhome. I wanted to install the 440 on an engine test stand and run it. The flywheel and bellhousing are needed to start it.
The bellhousing and flywheel will bolt on, but you will need an external balance flywheel for that year 440.
running up my post count some more .
