Solinoids, sensors, the sun shell breaks (we upgrade em all to "the beast"), clutches burn up mostly 4th gear but all of em are suceptible, the valve body spacer plate wears out so the check balls don't completly seal off and sometimes they get stuck in the plate or blow all the way thru.
