Originally Posted by 72roadrunnergtx
There is nothing in common between the ’68-70 and the ’71-72 tanks or senders. Aeromotive sells a modified Spectrum 10a ’71 and up to mid-year ’72 efi fuel tank (vent ports on the driver’s side rear). Don’t see how it would fit however, the fuel pump ports are on top, top of the tank is right up against the trunk floor.
That tank incorporates the feed and return lines at the fuel sending unit - they moved the vent lines to the drivers side rear; I'm just trying to avoid the $720 price tag. I did some measuring in the garage yesterday and I think the Holley drop in pump just might fit.
