The 80ish Mopar cast intakes have the off set thermostat location on the intake. Those intakes have the EGR port, but blocking it off doesn't have that much effect on performance. Then you can just use the Mopar pulleys from the same time frame. All the 80s Mopar squad cars used that intake.
If you need to have an aftermarket intake, start building the brackets.
