Originally Posted by A12
Originally Posted by VITC_GTX
Originally Posted by crackedback
I've used foot powder spray in the areas of most likely leaks.
When I drive it around "the block" ( 3 miles ) it leaves a 4" puddle of oil on the shop floor in 10 minutes. It's REALLY leaking.
Coat both sides of a new pan gasket with Loctite 515 Gasket Eliminator (or Loctite 518 GE) and put that out of the way. I've used Loctite 515 Gasket Eliminator for decades and never a bad result.
I used the Right Stuff which most folks like. I may have to give the loctite a try. I have a windage tray so I have two gaskets to worry about.
