Originally Posted by Old Ray
So, to this country boy the solution is simple, buy a GM powered hot rod cheap and buy a boat. Take the GM engine out and use it for an anchor for the boat. Install whatever engine you want. Problem solved. up
Agree, except, there are enough of those GM guys out there the sale of the "Corvette" motor will go a long ways toward funding a nice Mopar motor build. Much of the hard work has already been done on a drivable car. You can sort out what has to be done before you pull the GM motor & trans.
