When in doubt, measure enough times to remove all DOUBT i like those measurements
Good for you
Yes sir! I also verified with a T-gauge and micrometer measurement...That was within .0002" of an inch of the direct measurements with the dial bore gauge...so definitely happy!
Hoping to get the mains switched around and re-checked and get the rods done tonight as well.
