Make sure and use the same brand for the hose and fittings, I use the Teflon line hoses for all oil and fuel lines, it will hold a lot more pressure and with stand a lot more heat than the other non-Teflon line type AN hoses will up scope wrench It is smaller in diameter and lighter also up Not as flexible though shruggy work
