Originally Posted by dragon slayer
Originally Posted by JohnRR
Originally Posted by David1971
Originally Posted by 440lebaron
V6?? fits all mopars 1961-1972 single point distributor , higher spring tension for high rpm use
Oops! Didn't mean to put V6. I edited that part of my post. Should read 6 cylinder.
David
But it can't be for all as your edit shows , small block and big block points are different, ... don't know about /6 .... , rotation of the distributor is different so you can't interchange . Make sure you get the right ones for your engine application.
Not true for Single point. Parts book calls out the same single point contact set regardless of engine type. Dual Points are different.
Ok , my bad I was thinking dual point because my 383 Dart has dual point ... carry on
running up my post count some more .
