I know there are garage heater kits for some refrigerators, but there isn't one for the frig I have. Its older and uses r134a for refrigerant. Works fine when the ambient temperature is 50 or above, not so much when it 32 or lower. Thanks.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
