Not to be negitive but If the hood is lifted up with a bit of force that fiberglass holding the saftey latch is a goner.
That's a good point, hadn't thought of that.
The fiberglass header portion is pretty thick, but I'm pretty sure it would be be good for <50mph.
Up at highway speed, 70-80mph, probably gonna be a problem.
So you got me thinking, I might need that pressure switch to trigger a buzzer deal to really idiot proof this thing.
Buzzer will go off immediately, and the latch will give me enough time to slow down.
I'm getting trained to look for that pink ribbon, so all this may be unnecessary, but then again, never thought it would have happened in the first place.
I appreciate all the replies, wealth of knowledge here is awesome!
