Why are you dicking around with this? You can buy a brand new 143 tooth 360 balanced flywheel for under $90 at rock auto.
LUK LFW219
As for the drilling pattern, why would it be different for a 130 or 143 tooth flywheel? The imbalance needed is for the engine, the flywheel is irrelevant.
