It is a very, very impressive engine. The fact that it makes over 1000 hp with a hyd roller cam and beehive springs is what is so funny. And a seven qt wet sump oil pan. Not to mention the OEM timing chain, the skinny spark plug wires, the factory coil packs, etc. This engine really makes the point that what matters most is the cylinder heads.
