BILLET 4.2 and 5.0 LEVERS
Billet steel 4.2 and 5.0 ratio front band apply levers for just about any Torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RH, 47RE, and 48RE. Almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These levers are CNC machined from solid billet steel. They are much stronger than the factory powdered metal forging levers, which are known for failing under the higher line pressures that performance transmissions run. The ratio is laser engraved into the tip of the lever in a large font size so it can be easily seen both in and out of the transmission. These are 100% made in the USA. $49 plus shipping. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
