Originally Posted by GODSCOUNTRY340
Originally Posted by AndyF
Those numbers are the two barrel ratings. It isn't the same as a 4 bbl rating. It was a marketing gimmick to fool people into thinking they had 1350 cfm when they actually had a lot less.
Cubic Feet Per Minute (CFM) is the same whether it's a 2bbl or 4bbl, that's what the carb flows. It makes no difference if it's a 2bbl or 4bbl, the CFM is what that carb delivers. There's no difference in the 2bbl or 4bbl rating.
Nope
https://www.speed-talk.com/forum/viewtopic.php?t=32644
https://thecarburetorshop.com/Carbshop_carbsizesandCFM.htm
the 6bbl would be rated at about 810 cfm if flowed the same as the 4bbl. Better distribution is what made it shine.
