I'm assembling a low deck 511 with Trickflow 240 heads, Hughes engines rockers and comp solid roller. After getting the rockers installed I thought about checking actual lift at the valve vs cam card. Well it wasn't as close as I hoped... Even after trying 2 different length pushrods it's about .050 less than the cam card of .631 with the 1.5 ratio. I even checked the Hughes with a couple spare blue Mopar rockers I had and they were closer actually almost perfect. I was on the fence between buying Harland Sharp and the Hughes rockers now I'm kind of bummed. Would the correct set of HS's be a better option for the Trickflow heads? Or am I worrying about something not that significant?
