What price range are you looking for. Some of the good or better 2500 PSI plus electric or even battery pressure washers are priced equal or more than a comparable gasoline pressure washer. I have a Greenworks and it's worked very well. My friend has a Sun Joe and he swears by in a touts it every time he uses it in front of me. I put off buying a $850 3700 PSI Simpson with a Honda GX200 engine after using the Greenworks for a job I thought I need something more than it. Lowe's has both the Greenworks and the Sun Joe and a few others to see some specs.
Mike
