Originally Posted by jbc426
Originally Posted by mickm
I think Klein might make an automotive analyzer with dwell. Came up in my search, but didn’t look at the details.
Car is doing well, something up, either points, condenser or coil. Hence wanting to be sure where the dwell is.
How’s the cuda?
Is your Dizzy a factory dual point? I have my original on the shelf if you want to test those parts. It puts out a nice strong blue spark.
This is a bit pricey, but does the job and then some.
https://www.tooltopia.com/otc3505a.html
Yes, mine is an original, rebuilt it a few years ago. Was working well until the strap for the condenser rubbed through the insulation and was shorting against the distributor wall! I may just have an another bad condenser in there, so trying to figure that out
