Originally Posted by mickm
I think Klein might make an automotive analyzer with dwell. Came up in my search, but didn’t look at the details.
Car is doing well, something up, either points, condenser or coil. Hence wanting to be sure where the dwell is.
How’s the cuda?
Is your Dizzy a factory dual point? I have my original on the shelf if you want to test those parts. It puts out a nice strong blue spark.
This is a bit pricey, but does the job and then some.
https://www.tooltopia.com/otc3505a.html
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
