Originally Posted by moparx
you don't have to jump those terminals.
all that is needed is to wire the G terminal to the mounting bolt, completing the ground circuit. [a spade connector, short piece of wire, and a ring connector terminal]
however, doing that allows the car to start in any gear, so BE VERY CAREFUL if you do this !
beer
edit : the above i posted is used to bypass the NSS using the key to start the car. using a bump switch to run the valves requires hooking up the switch as the picture indicates.
sorry if i caused any confusion !
URR Butt crack was showing on that one 🤣🤣🤣🍻
BTW jumping the terminals will make the cat move if in gear with a Standard trans. But it usually doesn't take long for one to figure that out. Especially if the front of the car is on jacks stand's or such wink
beer
i have found the "cat" will move pretty quick, or get ground up into a ball of fur and guts if it's resting on the engine and the "car" starts, even if it is on jack stands............... biggrin
beer
I have a emoji for you but i don't need a vacation 🤣🍻
