Concur. Firm Feel is what you want. Be aware the 72 set-up is different from 73 due to the 73 having the ISO (rubber bushings) set-up. BTW I tried the PST poly in my 73 and wasn't impressed and then went the full FF set-up. Took some work (clearancing) but it's obvious and do-able.
Common sense is a flower that does not grow in everybody's garden
