Thermoquad with the electric choke was #9801 aftermarket. One was made for chevy's, 9806 (?) but with different linkage setup.
Choke rods are semi-simple, 1/8" steel rod. Drill a small hole in the end for a pin, or do a fine cut 360* close to the end for a clip.
Easy to bend, and cheap.
