Originally Posted by ruderunner
Contaminated fluid is a thing and checking the cap seal is a valid inspection.
Trapped air is also a thing. A scan tool that can cycle the abs valves is useful. Or, panic stops on a loose surface to force the abs to cycle.
Yep^^^ and Yep^^^
