" I have been following this post and had planned using an external oil on my 572 street Hemi. I'm now having second thoughts as i do not want those issues with priming every time i want to drive the car. Can an internal pick up be made to work with the 4.500 stroke? Is there a better external oil pan available to avoid these issues? "
99% sure the 4.500" stroke will not work with the internal pickup.
I had enough of losing a prime so hopefully the Peterson setup will eliminate the issue.
Being able to pre oil it before every fire up is an added bonus.
Its a PITA.
Some have no problem at all and other with identical components have nothing but trouble.
Go figure.
