Cheap interior, mediocre seats, substandard HVAC especially on mega cabs (I live in the depths of hell… your results may vary), broken air doors (easy dash to remove), if it needs ball joints use MOPAR…. or Carli if they still make them. Lots of failed gear boxes until they went with the upgraded one (new one had a HUGE sector shaft). G56 trans?? You’ll find it buzzes rpm’s at highway speeds and a lot of people put gear vendors on them. Did ALOT of injector replacements on those in the 150k range….. I really think they needed the filtration they have on the 13 and newer.
We had a 2005 and the seats were so bad that about every 100 miles you had to get out and walk around because your back ached so bad. Have a 2010 now and it's night and day difference.
