For what you are doing, the others have said it well.
I use cranks with the journal width for Chevy rod, but there are some 2.2 bearing rods with Mopar width if that is what your crank has. I won't comment on if the excessive side clearance with Chevy rod width on Mopar journal width is or is not a problem.
