It doesn't matter. Start it up and set the timing with a timing light and you should be good to go. If you have issues with spark scatter then drill a hole in the cap next to the #1 tower and confirm rotor phasing with the engine running. Some of those Mopar electronic distributors were designed wrong and under full vacuum advance the rotor would point between the towers and the spark would jump to the wrong cylinder.
