Originally Posted by HotRodDave
Originally Posted by lowell66dart
I currently drive a diesel Ram but have had 5.7 an 6.4 gas Rams. One of the first mods was always a lower temp thermostat. I live in South Louisiana. No need here to run those engines at that temp. Just want to keep the engine/tranny cool.
Actually there is reasons to run them at those temps, for one it keeps water out of the oil better and water is a direct chemical byproduct of burning gasoline. Also helps MPG a tiny bit.
All you need to worry about is that the oil temp hits 212 or higher to evaporate the water out of the oil! All the other mumbo jumbo is so the MFG. can hit their quotas. 190 stat will do that down here in the south!!
Making cars faster one at a time!
19 Challenger Scat Pack white
16 Ram Sport SB Regular cab black
14 Charger Pursuit silver
78 Magnum 400 gray
69 SuperBee 512 Passion 4-speed 4:10
